opnspaces
Mar 26, 2015Navigator III
I'm betting on a circuit breaker out on the trailer tongue. But just to be sure have you checked the two green 40 amp reverse polarity fuses on the fuse panel? There are holes on the back of the fuses that allow you to take a voltage reading without pulling the fuse out of the block. Check both holes on the fuses to a good ground and make sure you get 13v.
Also if you pull the cover you should see the POS and NEG terminals that feed the fuse panel. This is where the wire from the battery is connected. Linked below is a basic manual that shows where the wires are that go to the battery (page 5).
manual
manual
44,056 PostsLatest Activity: Jan 19, 2026
