ugabulldog's avatar
ugabulldog
help with removing side mounting bracket
The previous owner of Tundra had a truck camper and I am trying to remove side mounting brackets. I have removed back wedge piece that held onto frame lip, see pic, I have pried down on bracket and it won't budge, I wanted to make sure there wasn't anything else holding it on before I pried any harder? Also first pic shows another Tundra without bracket installed. Thanks.
https://flic.kr/s/aHsmqZByNx
  • Those look like they could be Torklift tiedowns made for no drill installation. Can't tell if front or rear.
    The installation instructions should be online and they probably give you a hint. Do a web search for "20xx Tundra Torklift tiedowns installation instructions" and see if you find what you need. You could also go to their webpage torklift.com and find the tiedown part number for your truck and then search for the installation instructions for that part number.
  • I'd verify there isnt a nut inside of tube tying to body mount bolt,
    also look into receiver verify no other body rivet keeping it from sliding down -course that would mean receiver welded on in place-unlikely.
    Other than that run a grinder or cut off wheel partially thru corner of lip to bottom to weaken, insert something into receiver to pry down...
    Or reinstall and paint- just abandon.
