ScottG wrote:
And stop using silicone, it's no good for rv's. Plan on removing it and using the right products.
Agree, I hope you are using the generic term "silicone" and not actually using silicone. If you are, I would strongly encourage you to remove it and use a caulk meant for RVs.
When you say the "top part" of the window, do you mean the top of the window itself, or the top of the ledge that the lower portion of the window sits upon?
If the wood is wet from ABOVE the window, that is a bigger issue. That means that water is getting in from above that opening, which could be anywhere. Likely it is the roof, the AC, plumbing stack or something else that the seal has failed. I might bite the bullet and get the trailer pressure tested, that is your best bet for determining the actual leak. Eternabond tape over the roof/wall seam is a great option, and Dicor (or equivalent) on the rest of the roof openings should help as well.
If the wood is only wet where the window sits on that little ledge, it is most likely a window seal issue. Those are easy enough to fix. Hopefully you didn't use putty, but butyl tape. A good bead of butyl tape, topped off with a little caulk should seal it better than new.
Good luck!
