MFL
Nov 20, 2016Nomad II
It is a little hard to tell what line is for what from pics. I would say shut off from tank should be closed, and line opened from hose that goes in anti-freeze jug.
The blue tabs on pump are to release fittings from pump. You should not have to do that, if you have a winterize kit already installed, which sounds like what you have.
On mine, I made my own kit by pulling blue inlet tab, pulling fitting out, and adding my own short hose, with fitting, back into pump, lock blue tab. Then I just put my short hose in the jug and pump.
Jerry
Jerry
