IdaD
Jun 25, 2021Explorer
C.B. wrote:Geo*Boy wrote:
I have had very good results with Timbrens. They make a kit, FR1504E, for your truck and you can remove the supplied spacer to adjust the ride.
Ditto:
Timbrens work great on my F-350. No messing around with air compressor.
C.B.
x3
I probably have a little less than 1" of space between the Timbrens and axle unloaded, and it settles down with a heavy load. I think it improves the heavily loaded ride quite a bit without being overly harsh. About $200 and zero maintenance.
On a Ram 2500 specifically they also ride outside of the coil springs so they effectively widen out the suspension on the axle.
