valhalla360
Jun 25, 2021Navigator
Itakethe5th2011 wrote:
If price is no object, air bags would be the best way to go. The problem with air bags, you will need a air compressor, a controller in the cab, (to adjust the bags hight) and the air bags with mounts. Then you have to hook it all up. I removed my bump stops and installed Timbren Suspension System. It took less than a hour to install. The bottom of the timber sits one inch above the axle so it will not change the ride of my truck. Once I load the 5th wheel, my truck squats a little over a inch. It is more stable side to side and no maintenance required.
Having a fully automated system is nice but not needed. Run the valves back to the rear bumper and use a bike pump. Unless you are airing them up and down several times a day, it's not a huge imposition. They don't hold a lot of air. You still have to worry about leaks over time.
That said, we went with sumosprings on our F250. 1 bolt per side. Biggest issue was getting the old rusty bolt out. On a newer truck without rust, should be a 15-20min job.
They are progressive, so unloaded, they don't create a harsh ride.
