Grit_dog
Jun 25, 2021Trailblazer
Itakethe5th2011 wrote:
If price is no object, air bags would be the best way to go. The problem with air bags, you will need a air compressor, a controller in the cab, (to adjust the bags hight) and the air bags with mounts. Then you have to hook it all up. I removed my bump stops and installed Timbren Suspension System. It took less than a hour to install. The bottom of the timber sits one inch above the axle so it will not change the ride of my truck. Once I load the 5th wheel, my truck squats a little over a inch. It is more stable side to side and no maintenance required.
You don't "need" anything but a basic airbag kit and there is zero maintenance required. You musnt have had airbags before.
Although a little compressor or even a decent bike pump is handy to air down after you drop the camper for bobtail driving.
