- HannibalExplorer
Buck50HD wrote:
On the way to the lake ice fishing this morning, the best I could get was 14-15mpg at 65mph, but it was -21F. Driveline doesn't like to turn at that temp.
Got about 5mpg pulling the ice shack through 6-12" of hard pack snow in low range, at -20F:)
That and cold air itself is denser causing more wind drag. Even my Prius drops to 40~mpg from it's normal 48mpg at 72~mph when it's below 40~*F outside. - Buck50HDExplorerOn the way to the lake ice fishing this morning, the best I could get was 14-15mpg at 65mph, but it was -21F. Driveline doesn't like to turn at that temp.
Got about 5mpg pulling the ice shack through 6-12" of hard pack snow in low range, at -20F:) - ib516Explorer II
mtofell1 wrote:
ib516 wrote:
with my Magnaflow exhaust
Wow... that stock exhaust barely even got warm :) Exhaust is the one mod I'm eyeing but I'm waiting to get a few miles and see what options present themselves on the 6.4 Hemi. Do you notice much difference from stock exhaust? Low end? High end?
Sent you a PM to keep this thread on topic. - mtofell1Explorer
Wow... that stock exhaust barely even got warm :) Exhaust is the one mod I'm eyeing but I'm waiting to get a few miles and see what options present themselves on the 6.4 Hemi. Do you notice much difference from stock exhaust? Low end? High end? - ib516Explorer II
Buck50HD wrote:
ib516 wrote:
Here's mine on a level hwy, cruise set at just over 100 km/h ~65 mph. This is what the mpg looks like when 4 cylinder mode kicks in. As you can see, it's not summer cruising either.
6.4 Hemi mpg, winter, 4 cylinder mode
Looks nice but the average in small font tells the real story:B
Yep, reset it while idling in the parking lot waiting to pick my daughter up. The video was shot shortly after getting up to speed on the hwy. I can make it read 99 mpg avg too if I reset it going downhill:B - ib516Explorer II
Does yours convert to Canadian MPG or US MPG? When I change my read out to "english", it converts it to US MPG.
S
US mpg - Buck50HDExplorer
Looks nice but the average in small font tells the real story:B - spud1957Explorer
S - ib516Explorer IIHere's mine on a level hwy, cruise set at just over 100 km/h ~65 mph. This is what the mpg looks like when 4 cylinder mode kicks in. As you can see, it's not summer cruising either.
6.4 Hemi mpg, winter, 4 cylinder mode - ib516Explorer II
Buck50HD wrote:
ib516 wrote:
Buck50HD wrote:
In the last 5 months, I don't think I've driven my truck in any conditions where the cylinder deactivation would even come remotely close to activating. But, I don't haul groceries or commute with it. I also have not seen a direct comparison where there has been any significant difference in mileage between the 3. In fact, the 6.4 was consistently the worst in the PUT.com shootout. My 2004 2500HD 6 liter got the same mileage. There's a lot raving about the Ram mileage but I still have a hard time buying it.
I had a GM 5.3 with cyl deactivation and the only thing it did was cause stuck lifters on a cold start and sounded like it was coming apart. The mileage was no different than previous non-AFM 5.3's I owned. It was used to pass emission tests, not save fuel for the owner.
3/4-ton Shootout Fuel Economy
You must drive in some extreme conditions then. Once up to operating temp, the 4 cyl mode cuts in all the time on my truck - everyday in fact, several times in a 8 mile commute. It kicks in when city driving as soon as I'm up to speed. On the hwy, as long as there is no wind and no hills, it's in 4 cyl mode. As soon as there's an uphill grade on the hwy, it kicks into 8 cyl mode, and it doesn't take much of a slope. That said, here's a video of my hwy mpg. Why not post your hwy mpg? Surely, your 3.73s would have the advantage.
Here's a video of my truck's hwy mpg
I've seen your updates and I could make countless videos of 18+mpg cruising on flat ground in the summer. I've managed over 17mpg for an entire tank of gas so the steady-state highway cruising part of that was well over 18.
But, the reality is that as soon as I combine that with cold starts, warmups, idling(these things guzzle gas even at an idle), stop and go, short trips and towing, the lifetime average would not be dramatically improved with 1mpg better on the highway. That's what they proved at PUT.com.
BTW, in the same conditions as my 17.x mpg tank with the 6.2, my previous ecoboost netted 25.5mpg with non-ethanol fuel. And it towed a 9klb 5th wheel faster! Only slightly faster, so probably about as fast as a 6.4 Hemi:B
I'd like to see it on video. Put your money where your mouth is! :):B
