RinconVTR
Jun 13, 2017Explorer
BarneyS wrote:
There is no need to leave a lot of slack for movement with that hitch.
The longest the chains need to be is when the hitch is lined up in a straight forward line .
edit: I would check out the rating on those links connecting the cables and chains. They look considerably smaller (lighter weight) than the chain links and could possibly fail if needed.
Barney
You still need slack regardless of all things. I simply prefer how high the cables ride and pull the chain up. Some setups have the WDH bars pretty low and the chains even lower...this would help a lot.
The links are sized to fit thru the heavy chain on the trailer. I could use a pin type chain coupler, but the current threaded links have the same rating as the cables, so whats the point.
In fact, those links are the ones Hensley shipped with their chain extension.
Thanks for the concern though.
44,070 PostsLatest Activity: Aug 06, 2026
