DutchmenSport wrote:
"Complicated" is in the mind of the beholder! You probably did it right. If it tows right and feel right, it's right! You did a good job. Don't over think it, just do it and you'll be fine!
Getting used to hit the stinger is the biggest headache with the HA. I found you need to grease the tapered end and it will not stick and give a problem getting it apart.
I used it with 1400# bars on a 1500 Ram, Hemi, 2004 and Jayco Eagle 322FKS of 8,000 lb loaded. Pulled great.
I have a friend who thinks the hitch hates him. I would never let a mechanical object get the best of me. I mastered it and found hitting the stinger was a simple project after several outings.
Great hitch, enjoy the safety it gives you.
