nephi007's avatar
nephi007
Here's what it says
Howdy. The manual for my 2013 Silverado crew cab short bed says: 5.3L..V8..K5L HD Colling package.. 3.08 axle ratio..maximum trailer weight 6700 lbs..GCWR 12,200 lbs.. great..so I think I am looking at a max trailer dry weight of 5700 lbs or so given that 1000 lbs has to be set aside for hitch weight and such..so my question is: the Silverado one step up has a gear ratio of 3.42 and max trailer weight of 9500 lbs..How can I get my trucks gear ratio higher without voiding warranty. If i cant I guess I will look for the trailer that will work within my specs since I am keepig this truck. Advise please. Thanks! Passengers are me wife a 10 and 14 year old girls
  • You could have it changed at a shop and the dealer would never know. But if you do,put 3.73 in.
    To make a good decision about staying within limits we really need to discuss:
    GVWR
    GAWR rear
    GAWR front
    ....these numbers will be on the door sticker.
    Forget trailer "dry weight". Best to think in terms of what the trailer "really weighs". A pretty good starting point of discussion on that is 1000 pounds over the dry weight.
    If this is a 4WD truck, then changing gears is going to be fairly costly.
  • I know it would be expensive, but could you discuss changing the differential with the dealer?
  • put a 3.42 axle in it. Would be expensive.Unsure why you think it would void your warranty????
    What does changing your ratio have to do with warranty?
