BoxerDogs
Jan 07, 2020Explorer
Sam Spade wrote:BoxerDogs wrote:
It works like a standard septic only on a smaller scale.
About what I expected.
No it does NOT work the same.
It is illegal and dangerous......especially if located anywhere near a well.
Having lived in the country and used septic tanks fo a lot of years I assure you it is the same.
You have a tank and a drain field,just like a standard septic system.
Surely you've heard "the grass is always greener over the septic tank"
As well as over the drain field.
Oh....the nearest well,an artesian well that flows 24/7 is four miles away at the front of the property.
The camper sits on 6000 acres and is in the middle of nowhere.
And you also have to remember the thing will only be used by two people on weekends.
And of course you dump a bunch of Rid X in the tank as well.
