BoxerDogs
Jan 08, 2020Explorer
rbpru wrote:
While we do not fill the tank before dumping, we do dump before leaving the park. No sense hauling all that extra weight and **** around.
When we dump the tank, I usually flush about a 5 gallon bucket of clear water down the stool.
When the water runs clear through the clear plastic elbow at the dump slinky hose, we are good to go.
You can develop any method that works for you. Most people do. If you screw up once, chances are you will not make the same mistake again.
Good luck
Once we get the redneck septic hooked up it'll be easy enough to empty after every stay.
Like you said,if it's not full enough to properly drain I'll dump five or ten gallons of lake water down the john and pump it out with the macerator.
