Old-Biscuit
Mar 30, 2020Explorer III
Drop the tongue/front jacks & raise the rear of trailer
Slightly off level.....not good for draining waste tanks and Definetly NOT good for longh term reliability of fridge.
Is BLack Tank (larger pipe) draining OK?
DO you 23 grey tanks ---you state grey BACK tank not draining?
That could be galley tank and has it's OWN drain line/dump valve back behind tires etc
If only ONE grey tank---then a 'cutout disc' (holes cut into tank for vent line/drain line etc) may have fallen into tank and not removed. Gets sucked down to tank outlet and blocks it
44,068 PostsLatest Activity: Apr 17, 2021
