opnspaces
Mar 31, 2020Navigator III
From time to time we read about a manufacturer leaving the the plastic disc in the tank when they drill out the drain opening. But I would think that would cause a slow drain situation not a complete stoppage.
I think the most likely reason is there is a second gray tank. Maybe look again for a second drain handle, look inside the exterior compartments as well. If the tanks are exposed you might have to crawl under the trailer to take a look.
While I respect Old-Biscuits posts as he always seems to be spot on, I disagree with the leveling suggestion. Two inches difference front to rear on a 30 foot long trailer is not anything to worry about. But it won't hurt anything to level it a bit better. Well except on a trailer like mine with a rear bath I have to level it nose high so the water running down the walls in the shower dosn't puddle on the tub rim and run off onto the floor.
44,068 PostsLatest Activity: Apr 17, 2021
