Ride_S40T
Apr 04, 2020Explorer
Wow, if it's backed up then 1 of 2 things have happened. First, you may have a clog somewhere. Looks like in the specs that all 3 sinks drain into the 69 gal grey tank. 2nd...could you have possibly...or did they at setup leave both valves open?? You'd know this by having a fair amount of drainage when taking off the cap when preparing to dump. I say this because they did on mine...a friend of mine caught it before we headed out for the first trip.
The other issue may be more ominous...there a blockage downstream in the drain. There's water in there somewhere and a 2" drop left/right or front/back may cause a little water to not drain during dump but at 69 gal grey and 78 black...there should be gushing until the unlevel trailer holds a little back.
Call your seller and talk to the service dept. There's no "goofy" questions for them, they've heard it all. Much of it from me, probably. :)
When you find the issue, please post back. We all learn from these situations. Good luck.
44,068 PostsLatest Activity: Jun 17, 2026
