The battery guru's have established the safest way to charge batteries to get the best operating performance along with the best long life.
This is done with using the smart mode voltages you hear about being 14.4VDC, 13.6VDC, and 13.2VDC and this will basically need to feed your batteries at different DC VOLTs changes and certain periods of time to safely charge your battery and not destroy it. I am only talking about the standard flooded cells batteries.
This normally requires you to have a DC OUTPUT capacity of 17amps to 20Amps of DC current and only do your different charging DC voltages for a specified time frame. This will charge your deep cycle batteries safely to its 90% charge state in a three hour time period or to a 100% charge state in a 12 hour time period. Doesn't matter how many DC amps you have available to feed the batteries. These smart mode DC voltages will work with 17-20AMPS DC current for each battery in the battery bank for those specified times.
The only way to make the batteries draw more DC current is to raise those DC Charging voltages but then you will start running into doing damage to the battery cores starting with the boiling out of the fluids... Then the batteries get rather hot and may explode on you....
Having four batteries in your battery bank you only need to have around 80AMPS of DC current available to feed each battery the 17 to 20AMPS DC current that has been identified by the battery experts for the most safe way to charge batteries without damage to their cores.
I am old enough to remember what happened in the 50s when it was normal for a gas station to charge you car batteries in a quick 30 minutes by using maybe 50VDC as charging voltage with a capacity of a couple hundred amps DC current. Those large battery cables would actually jump when this was first applied and the batteries would immediately start boiling out fluids and getting rather hot. Most of them survived the 30 minute quick charge charge but some did not and would explode. I witnessed one such explosion and the top of the battery case blew up into the air some 20-30 feet and battery acid was sprayed all over the motor compartment and on the fenders etc of the car... Not a pretty sight...
In my Air Force days in the late 50s all of the truck mechanics had special enclosures to sit the batteries in while they were being charged to prevent the explosions from doing damage to the personnel...
Glad we don't do this anymore...
You can have all of the DC AMPS in the world but your DC Charging voltages will determine how much DC current is going to be used. I think it actually turns out a lower DC Voltage for a much longer time period does a better battery charge than the higher DC voltage will do for you in quickest time frame of three hours to 90% charge state or 12 hours to 100% charge state...
This is what PROGRESSIVE Dynamics states in their operating manual on how long it takes to charge a battery using the DC VOLTAGEs listed below:
"Progressive Dynamics ran this test on the amount of time it took a PD9155 (55-amp) converter/charger set to three different output voltages to recharge a 125 AH (Amp Hour) battery after it was fully discharged to 10.5-volts.
14.4-VOLTS (Boost Mode) – Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours.
13.6-VOLTS (Normal Mode) – Required 40-hours to return the battery to 90% of full charge and 78-hours to reach full charge.
13.2-VOLTS (Storage Mode) – Required 60-hours to return the battery to 90% of full charge and 100-hours to reach full charge."
This is based on having 17-20AMPS DC current available for each battery in your battery bank...
NOTE That Progressive Dynamics doesn't even list using DC Charge Voltages around the 12.0VC range as this would take alot more than 100 hours to achieve a 90% or 100% charge state.
Not an expert here just a shade tree mechanic and have been charging batteries on my OFF-GRID camping experiences since 2008...
In my case if I just charge a battery for 30 minutes off and on during the day my batteries will start going down hill on their performance lines rather quick and eventually will fail... I always start each day off with at least a 90% charge state and never let my batteries go below the 50% charge state... The deep cycle batteries work well with this routine for me... After around 12-14 cycles of the 50% to 90% charge states I always have to do a full 100% charge state which takes a minimum of 12 hours or so using the current days smart mode charging DC voltages.
One needs to talk with folks like MEX from down south on his charging batteries experiences to get a good understanding on getting best results... MEX is a General Motors expert and is especially outstanding in the Alternator field...
I would love to have a high output Alternator setup but would still follow the same safe charging routine outlined above. I could just do this to more batteries in my battery bank at the same time frame...
Roy Ken
