ATF+4 is a full syn fluid and good for all Chrysler transmissions built after 1990 if I remember correctly. Will double check later, right now the $#&%$+@ pager is going off agian.
Don
ATF+4® is approved for use in older transmissions and is currently utilized in newer Chrysler®, Jeep® and Dodge® vehicles. The previous MOPAR ATF+3® formulation was discontinued in 2005 and ATF+4® is recommended for all transmissions filled with ATF+3®. Only certified ATF+4® is recommended for service of Chrysler Group LLC vehicles. The use of automatic transmission fluids other than ATF+4®, including those claiming to be like ATF+4®, could result in lower levels of performance, jeopardize transmission life and void warranties.
