work2much wrote:
Interesting. Would you share details of your inverter install? I have considered doing the same to power the campers inverter/charger which would not only run the fridge but also charge the campers battery bank.
I installed inverter in truck. We have an 1100 watt inverter in camper I could have used but this allowed justification (approval) to add one to truck which I've always wanted to do.
Plus unsure about delivering needed DC charge from truck if used to power inverter in camper. Almost always easier to run output from a elec. device than needed input.
Think maybe I misread though. If installing/using a truck inverter, possibly plug camper directly via its shore cord, using its converter/distribution to charge & run fridge? Hmm simply hadn't occurred to me. My AC output from truck is hardwired to truck bed-have added separate AC cord from fridge- that's all it runs. But 'could' plug camper AC cord in to bed receptacle...not sure about the amperage or draw of converter. Or at least potential? My inverter is only 1000 watts-
Likely some one has done that- dont think my setup would work- possibly but..
Thinking about it, with fridge on AC/supplied by truck, factory charge line (& in my case +solar, aux charge line) to batteries the converter likely wouldn't be doing anything but passing AC to fridge. I guess the variable would be if camper batteries need charging the load converter would add? Ive never really seen those numbers. wandering...
As to details of my install- Likey have to split this post up due to forum issues with 'service temporarily unavailable...' and Captcha issues...
