languiduck
Jun 21, 2017Explorer
Something isn't adding up. Speed bumps aren't placed in locations where vehicles travel at speeds that would allow them to become airborne and break a torqlift tie down.
Anyway, I don't know where your water tank is, so I can't say how to remove it. All the ones I've seen can be accessed from inside and would be easy to replace and service.
As for the tie downs, if they are torqlift, they will most likely send you a new set to install...I would go that route since you paid so much for them.
I'd recommend speaking with the campground owner about your repair; you will probably have better luck communication with him first so that he doesn't freak out when he sees you rebuilding a camper.
