HadEnough
Jun 21, 2017Explorer
Troutguy wrote:
You have to remove the bottom of your camper to access the fresh water tank as it's suspended by nylon webbing to the frame. You can't replace it from the inside of the camper. Was the tank full when you incident happened?
Thank you. And yes. The tank was 2/3 or so when it happened and developed a crack near the bottom of the tank (holds no water... All leaks out)
Hmmm. I'll have to find some of this nylon webbing I suppose as well. Hope this project goes smoothly.
I've built 3 of my own RVs and a 50' catamaran so not too worried, but... I need to keep it fast and tidy so as not to cause any problems at the campground. Just a quick water tank replacement.
44,070 PostsLatest Activity: Aug 05, 2026
