Grit_dog
Apr 07, 2016Trailblazer
A long hitch ext like you're getting requires a truss type hitch and sway braces without question.
I'm typically on the liberal side when it comes to weights etc but imo you need to think about the whole setup before getting a 11' slide in if you plan to tow. You'll spend $ on a good receiver for your truck, rear tie downs will be different likely for the camper and after all that you got a huge hitch extension. It's do able but not ideal imo.
Better have a lot of truck. You're into dually territory for sure the way you're headed with this.
44,070 PostsLatest Activity: Aug 05, 2026
