Bedlam
Apr 09, 2016Moderator
Phil Hendrix wrote:
Honestly if I had even the slightest intentions of towing any significant weight at all, it would be a no-brainer decision for me ...I would get the superhitch and not look back. But seeing that I don't even know if I will muster the guts to tow anything behind the already very large and heavy TC I will wait on spending the money for a hitch I might not use.
There are light duty less expensive options available for you if you don't plan to change how much you will tow. If you do end up upgrading to the SuperHitch later, your replacement cost will be for the receiver, rear tie downs and extension. It is overkill for your current application, but it opens up more possibilities later without having to buy equipment again.
