CAJW
Feb 15, 2015Explorer
I use a Tilt-a-Rack plugged into a Superhitch with a 32" extension. After doing a ton of research and number crunching, I determined that although the carrying capacity was diminished due to the extended arm, it was still within limits. It has thousands of miles of use without a problem, but I did modify it from day one. If you look closely at the rear wheel of my bike you'll see a loose cable which I attach to one of the hard point mounts for the camper jack to help stabilize the setup from rocking excessively. The driver side also has one which I sourced quick release turnbuckles used for sail boat masts to allow for a quick disconnect. It allows us to get into the camper without having to step over the cable. Another option to up front, but others have shown that works too.
44,071 PostsLatest Activity: Aug 30, 2026
