mike/kellie wrote:
I can only respond to the braking system. I bought the Ready Brute with surge. I bought a new Ready Brute tow bar from a member here, and then purchased the base plate and separate surge extension. I didn't want wiring going through the jeep. I have 2 cables mounted to the brake pedal through the firewall. One is emergency break aware and the other is surge cable. Brake, turn and tail lights are the magnetic type ( battery fed led ) secured to cargo basket over the spare, fed my transmitter plugged into the 7-way plug.
Great father's day present from my kids that performed perfectly last month.
Spider senses flashed seeing a single tube extension. Looking at my Torklift, 2 tubes fastened together with 3/8" chain turnbuckles.
X2 on Mike/Kellie's concern about a single tube. I think you will find that the Mammoth is 11 1/2' long, and that you need a minimum 42" hitch extension. I use a 48" Torklift truss system on my Mammoth to put a little more distance between what I'm towing and the back of the camper.....
