TxGearhead's avatar
TxGearhead
Explorer II
Mar 29, 2018
Hitch extension source?
I'm looking for a 18" hitch extension. I want a 2 1/2". I "think" I want a solid bar instead of the tube. I'm assuming it's stronger. I just want to tow a 13' utility trailer with a ATV, or my 18' aluminum john boat. I'm sure a hollow tube would work just as well but..
I've looked everywhere I can think of. Probably overlooked it though.
  • the 2.5" extensions fit into your truck receiver, but use 2" receivers on the trailer end.
    I run a curt at either 36" or 48" depending on what I am towing.
    With any tong weight I really recommend Weight Distribution hitch.
    because my weight distribution receive is longer than my normal drop receivers I can can run my extension at 36" instead of 48. And the weight distribution really makes a difference. I had a set of 600lb bars laying around. I think the camper rides better with my 7x14 V nose behind it with Weight Distribution hitch then the truck does without the camper.
  • I know you want a solid 2-1/2" 18" extension. I've towed our 7,500 lb carhauler trailer many 10's of thousands of miles on a 2-1/2" X .25" wall 22" extension. Just something to consider.
    http://allmetalsinc.com/hs2500.html
  • I got a 48” extension from Etrailer. Works great with towing my bass boat behind my TC
  • If this supplier doesn’t have what you’re looking for.....it probably isn’t available.
    https://www.etrailer.com
  • What a problem to build one?
    In California I had ACE Hardware Truck Accessories supply that had good selection of receiver tubing. Than you buy solid bar at fabrication shop and weld it.
    Lot of such stuff on amazon.
  • You can find an 18" long 2" extension from online vendors lie Tweet'y, Curt, Reese, etc. The 2 1/2" extensions start at 24" and go up from there, so your choices are restricted unless you make something yourself.
