I currently have the Reese 48 inch extension, the limit on this is 6,000 lbs with a weight distribution hitch. I am considering a 20 ft cargo trailer (3000 lbs), with a Rzr 4xp (1700 lbs), an ATV (400lbs), maybe a dirt bike(500 lbs). So I will be under the limit of 6000 lbs, just barely. Anyone go this route? It will be for a Host Mammoth not sure what the rear offset is, if I use it at 41 inches I can tow up to 7500 lbs. Obvioulsy I am not going to cheap out if there is a risk, just curious if anyone used the 48 inch standard extension before to the maximum capability.
https://www.etrailer.com/Hitch-Accessories/Reese/RP45018.html
