Jebby14
Jun 01, 2018Explorer
hitch grease
what's everyone greasing their hitch with? always just used a smear of Vaseline on the ball but suspect now that I have a pro series WD hitch that calls for grease with each use I should get an oil? L...
SoundGuy wrote:big_jeff wrote:
I never grease the hitch.. I read somewhere that the ball and trailer hitch act as a ground and greasing it would defeat that purpose. The newer brake controllers use that ground and you may get an error using grease.
Incorrect ... ground is provided via Pin 1 on the Bargman connector so there's absolutely no reason to not grease both the ball and coupler.
