- thib2722ExplorerYou can grease everything BUT the friction plate on the anti-sway device. The sway is controlled by friction, much like a brake, so greasing it would defeat the purpose.
- ZeeLet50ExplorerTo clarify, its an Equalizer-II WD/sway control hitch. The bars do slide some as the steering angle changes but according to the wear marks only about 2". They do pop and creak as I turn.
- HJGyswytExplorer
Montana Mike wrote:
equalizer hitch bars
I don't think we are all on the same page here. When I read the above, I assumed Montana Mike was talking about his "equalizer" bars as in weight distribution. If he's talking about the friction bar you add to the side of the hitch and frame of trailer I say not necessary on lube. But if it is a combination "weight distribution/friction control bar" then certainly lube the pivot point. - HuntindogExplorer
ZeeLet50 wrote:
the pivot area next to the hitch is 3 feet away from the contact area so I don't think I would have a prob with grease migrating from one to the other
We are talking about a standard friction control right?
The kind that has a flat steel bar that slides into 2 friction material brake pad type things?
If so, then it shouldn't be 3 feet, and the distance changes growing and shrinking with every turn. In fact it can be close to zero in a tight turn. That is how the lubricant can make its way onto the pads. - ZeeLet50Explorerthe pivot area next to the hitch is 3 feet away from the contact area so I don't think I would have a prob with grease migrating from one to the other
- HuntindogExplorer
ZeeLet50 wrote:
^^^ there is the clarification I was looking for. I was told not to lube the bar contact points but it makes sense to lube the ball/socket head area. Thanks.
I wouldn't do it. Those little 1" balls don't have enough pressure on them to gall. And any lubricant on them will eventually find its way onto the friction area. - ZeeLet50Explorer^^^ there is the clarification I was looking for. I was told not to lube the bar contact points but it makes sense to lube the ball/socket head area. Thanks.
- HJGyswytExplorer
Montana Mike wrote:
I thought I read not to grease your equalizer hitch bars as that will take the anti sway effect away if the bars slide easy?
Not the friction end where it connects to the trailer, but the pivot points where it connects to the hitch head.
So many different kinds of weight distributing hitches on the market, a person really needs to know all the features of the one they own. - dave54NomadI use bicycle grease.
I do my own bicycle maintenance and always have a tube with my tools. Bicycle grease attracts and holds water and dirt less than automotive greases, and is less abrasive when it does get entrapped grit. - Montana_MikeExplorerI thought I read not to grease your equalizer hitch bars as that will take the anti sway effect away if the bars slide easy?
