Jebby14ExplorerJun 01, 2018hitch greasewhat's everyone greasing their hitch with? always just used a smear of Vaseline on the ball but suspect now that I have a pro series WD hitch that calls for grease with each use I should get an oil? L...Show More
rbpruExplorer IIJun 03, 2018Most people grease, some do not. I do because I like some lube on moving parts.Even with heavy grease you will wear through the chrome plating, it just takes longer. Frame grounding is pretty rare the days, but the grease does not insulate the metal to metal contact.
Related ContentGreasing the hitchHitch ball greaseGrease gun/ grease recommendationsWhite lithium grease for the hitch?grease for 5th. wheel hitch???
