Oasisbob's avatar
Oasisbob
HITCH HEIGHTH ?
I am installing my old class 3 adjustable heighth hitch on my new to me Ford Explorer with factory receiver. On the lowest setting my ball is still 2-3 inch's taller than my trailer hitch is when trailer is level. This is unhooked. Do you think my Explorer with factory tow package will sink down a few inch's and work? I do use load leveling bars. Option B is to purchase a different hitch that will lower the ball another two inch's. What say you? I know for sure you guys know more than I do. Thanks in advance.
  • wITH MY RIG ON LEVEL GROUND MY tv SITS TWO INCH'S HIGH FROM BEING LEVEL. sO i AM BUYING A DROP UNIT. hOPE THIS MAKES ALL WELL.
    tHAt tYpING iS hOrREndOuS, SoRrY
  • agesilaus wrote:
    Hook it up and check it. You have a WDH and that doesn't have it's own receiver?
    OP has a receiver on the vehicle, he is asking about the shank of the hitch. Most WD hitches have a head that bolts to the vertical holes of the shank with two 3/4 bolts, which allow you to adjust the height of the head. There is no way to know until the OP hangs the trailer on the ball and sees what happens. If necessary the head can be moved up or down the shank, or the shank can be rotated so the offset of the vertical part is reversed. New shanks can be purchased with more drop or rise, but probably not necessary.
    Charles
