mekkerl's avatar
mekkerl
Hitch Prep??
I am in the market for a used 3500 diesel truck to tow a FW. My search is almost entirely online, as these vehicles in my price range are hard to find locally, therefore I am willing to find one 1,000-miles away.
I would like to know what I should be looking for regarding if the truck is 'prepped' for a fifth-wheel hitch.
I have specifically found a few 2011-2013 Silverado 3500HD Diesels that I like...but by looking at pictures of the bed, they do not have any indication that they are prepped for a hitch mount.
Of course, I really don't want to purchase a truck 1,000 miles away, only to find that major work needs to be done before bolting a fifth-wheel hitch to the bed.
Help!?
  • Gm just recently came out with FW prep kit. Easiest tow vehicle to find with a factory installed FW prep kit is a FORD, years 2011 to current.
    Best hitch for it IMO, is a B&W 3300.
    Jerry
  • Thank you for the quick responses!
    I am looking at SRW standard bed (6.5'), so would need a sliding hitch after researching.
    The FW we are looking to get has a GVRW of 15,500 and also has the corners 'cut' out of the front end for easier turns, etc...
    I assume the B&W turnover ball has to be factory installed?
  • Best thing if you are committed to a used GM is the B&W TurnoverBall gooseneck hitch. Then you have a clean bed when hitch is removed. I would highly recommend the 20K companion for a rock solid hitch.
    The 13 and newer RAM trucks have the pucks as a factory option or they can easily be added.
  • You can buy a set of custom fifth wheel rails from etrailer for a couple hundred bucks that will bolt on in an afternoon, so any truck without a factory fifth wheel prep kit can be equipped to haul a fifth wheel pretty easily.
