- bgradertExplorerGood info. I saw a rack that mounts right behind the LP tank last weekend while camping. It looked pretty solid but it prices out around $300.00.
My unit is jayco Whitehawk 28dsbh, 2015 model. - Need-A-VacationExplorerDo not do it!!! As you mentioned and sound concerned with, the bumper is not strong enough at all to support a bike rack.
You have a '15 Jayco? Is there a tab on the bottom of the frame behind the rear scissor jacks on each side? Look in my mods link for the optional Jayco rear cargo receiver hitch we added to our 32. It bolts on to the frame mounted tabs, and is pretty solid.
Even still, make sure you get a good bike rack. Some are rated for use on the rear of a rv. I also use one of the anti-rattle kits to keep our bike rack from moving in the receiver hitch.
Just looked up your model. Didn't realize it was a Whitehawk at first. Jayco unfortunately does not list the optional rear hitch like what we added.
I would suggest finding a local welder and talk to them about adding a frame mounted hitch. They may even just reinforce a bumper mount hitch so it is also tied into the frame. A buddy had that done. The welder made the bumper mount into a "T" that extended toward the front a foot or two, then tied into the frame on each side. No pics and they have a different trailer now. - Nicholsfamily05ExplorerWe have one on our RV but we checked the mounts on the bumper and they go directly to the frame and are welded and bolted with rather thick steel.
You should see how your bumper is mounted first and then see also how thick your bumper it's self is as well.
We use our bumper because it is designed this way.
44,052 PostsLatest Activity: Jun 10, 2015
