scooterpuller
Oct 09, 2014Explorer
hitch weight
im getting ready to buy a freedom express 301blds but found out that the hitch weight is 950#'s and my truck,f-250 diesel srw,is only rated for 850#'s...is it too much over or will it be ok
scooterpuller wrote:
thanks everyone for the responses...i have a 2014 ford f-250 with factory hitch,6.7 diesel and tow package...i didnt know about the sticker,i will look for it ,as far as where i got the 850# info,it was in the owners manual..thanks again and thanks for being patient with this newbie
Ron Gratz wrote:tomman58 wrote:That's true -- but you still will end up with a net increase in load on the rear axle.
Weight distributing is sending more to the front.
If the tongue weight is, say, 1200#, attaching the TT with no WD applied will cause the front axle load to decrease by about 500# and will cause the rear axle load to increase by about 1700#.
If you adjust the WDH to restore 50% of the front-end lost load, the rear-end added load will decrease to about 1350#.
If you adjust the WDH to restore 100% of the front-end lost load, the rear-end added load will decrease to about 1000#.
So, it's likely you'll end up with 1000# or more added to the rear axle relative to the unhitched load.
Ron
Ron Gratz wrote:tomman58 wrote:"lesser weight" -- please explain?
Can't imagine a Ford diesel with a light hitch must be really old.
I tow with 1100# tongue weight and 1200# torsion bars no problem other than lowering the tire pressure on the rear tires as they will burn off center tread after 15,00 miles because of lesser weight.
If you're towing a trailer, the rear tires should be carrying more weight.
Ron
