scooterpullerExplorerOct 09, 2014hitch weightim getting ready to buy a freedom express 301blds but found out that the hitch weight is 950#'s and my truck,f-250 diesel srw,is only rated for 850#'s...is it too much over or will it be ok
downtheroadExplorerOct 09, 20142 things going on here.1. The hitch weight you posted (950 lbs) is probably the dry weight. It will be much higher.2. The truck hitch rating you posted is most likely the number without weight distribution. It also will be higher with a weight distribution hitch.
Related ContentBest Weight Distribution HitchActual Hitch Weight vs Dry Hitch WeightDry tongue weight versus fully loadedHitch weightWeight Distribution Hitch
