Hi all...considering buying a 2015 denali hd w diesel. ..payload capacity is 3000 pounds. If fifth wheel hitch wt is 1500 pounds do I assume I subtract that from payload leavingeme only 1500 pounds in...
The short answer would be yes. However, I think you have your hitch wt wrong. Most FW hitches would only weigh 200-250 pounds.
I did not quite understand your post, but yes, on the pin weight taking from your payload. Now you will also have to subtract the weight of the FW hitch.
