handye9 wrote:
Capeteacher wrote:
I was talking with a friend about some of the TT I am interested in. I told him the Xterra has a 500lb hitch limit and I was looking for TT with a low weight so that when the WD hitch is attached and battery and propane are added the weight is still under the limit.
He said the hitch weight listed already adds in battery and propane. Agree or disagree.
As you can see, your results are about 50/50. Some manufacturers include that weight, some don't. You really can't count on dry hitch weight being accurate, or, even close when loaded for camping.
As for true hitch weights, there are other factors (in addition to propane and batteries) that need to be considered.
1. The weight of the weight distribution hitch itself, adds 80 to 100 lbs of dead weight on the vehicle's hitch receiver, and counts as cargo weight against the vehicle's available payload. If the receiver is stamped 500 / 5000 lbs max, part of that is used up by the weight distributing hitch itself.
2. True hitch weight is not a constant number. It goes up and down during every trip. Different things get loaded in different places, groceries get loaded and used up, and holding tanks, depending on their location (in relation to the trailer axles) and fluid levels, can add or subtract considerable hitch weight.
My travel trailer had an advertised "dry" hitch weight of 880 lbs. My fresh tank is behind the axles, black and grey tanks are directly above the axles, and I have a galley tank in front of the axles. Water in the fresh tank takes hitch weight away. Water in the galley tank adds hitch weight. During any given trip, my actual hitch weight can fluctuate between 975 and 1200 lbs. With the weight of the WD hitch, my receiver is actually carrying 1075 to 1300 lbs.
So the weight on he hitch varies depending on where the cargo is stored and the WD hitch weight. Ok got that, thanks. How do I use this info to determine what TT to buy?
