oil8390
Feb 21, 2019Explorer
Holding Tanks
a question regarding the holding tanks. I have a 25 gallon black tank, how much water should i add to it before i use it for the first time in our new trailer and whats the easiest way to do that?
3 to 4 gallons. Empty your black only when it is almost full.
When you see/hear a gurgling and a bubbling sound, it is time to empty. If you have a back flush connection on the side, hook it up before you start emptying your black tank and leave it run until the tank is empty. Then close the black valve and let the black tank fill about 1/2 way, then open the black tank valve until the tank is empty again, this will wash down the inside of the tank. Close the valve and put in about 3 gal. of water. Job done
