- beemerphile1ExplorerYes, that is a vacuum breaker/backflow preventer on top of the valve. It should not leak water during use but will open and drain some water when turned off. Its purpose is to prevent dirty water from being sucked back into the system and contaminate the fresh water.
- smokey988ExplorerYes that is it. is that to stop a vacuum?
- JJBIRISHExplorer
- smokey988Exploreryes. A hole located on the underside of where the hose hooks up. I will get a picture and post it.
- beemerphile1ExplorerHole? Shouldn't be a hole. There is a backflow preventer built into the unit that will relieve pressure when the valves are turned off.
44,068 PostsLatest Activity: Jun 01, 2026
