korbe
Apr 28, 2014Explorer
Mine started to flex or bow when my drain valve got hit by something kicked up from the tire and started to leak. The leak got the 3/8" plywood wet and lose it's strength. My rig also had 3 metal straps under the flexing plywood. When I took the plywood out there were all sorts of construction leftovers between the plywood and the water tank. I replaced mine with 3/4" plywood and everything is working just fine- so far.
