AtlPhilip
Jun 02, 2016Explorer
One comment about weight. The FWT on my 12yr old Starcraft sags as depicted and has never had any water in it.
I contacted Starcraft and their only suggestion was to replace the tank. I asked about installing a bulkhead and they only offered this, "you should be safe in adding a low point drain or a sort of plug as long as they are sealed correctly"
I'm considering putting a 1/4" SS self-tapping screw at the low point, and simply removing it to completely drain the tank. My concern is that it may start a crack or tear.
