- DonkeyEarsExplorerThanks for the input everyone. It turns out the shore power cord was bad. I put in a new one and it works great. Thanks again
- beemerphile1ExplorerYou have a ground fault.
Research ground fault and how a GFCI works. - stevemorrisExplorerexcellent point about the gfci
most trailers have at least one gfci and if the traileris plugged into a gfci protected circuit, things will go funny - myredracerExplorer IIBecause your home breaker does not trip when you have the trailer main breaker turned off but trips when turned back, that would indicate a ground fault somewhere on a branch circuit in the trailer. I would turn off ALL branch breakers in the converter panel and one by one, turn a branch breaker on and off until you find one that trips the house breaker. There are a number of things that can cause a ground fault inside an RV, one of which is a faulty heater element. If it appears that it is the element, try turning the heater off at the switch at the heater and see if the house breaker still trips. If it does, it should be a faulty element.
A weak or defective GFCI receptacle (or breaker) is the last thing that should be suspected. If they trip on ground fault (and not from overload or short circuit), then it is just doing it's job and protecting someone from a shock.
BTW, having GFI receptacles in series is not a great idea. Not unsafe but they can "fight" each other and one or the other can trip. For example, you could actually have a ground fault downstream of a GFI receptacle in the trailer but the house GFI is tripping instead.DonkeyEars wrote:
Well, absolutely everything is turned off in the trailer. The home circuit is a gfi breaker, I just push the button to reset. I don't think it's the home breaker, I run my compressor, power washer etc off this circuit. The shore power cable does have some cracks in it next to the metal prongs. It could be the shore cable as suggested. I tried turning off the trailer main ac breaker, and no home breaker kicked off. But it did kick off the home breaker as soon as I turned on the trailer main breaker. Unless there's any other suggestions, it looks like a new cable to me. Thanks a bunch. - a-d-sExplorerI had same problem as the previous poster with the hot water hearing element. $10 fix. Easiest way to check us to disconnect the hot wire at the panel that goes to the heater and plug it in again. That is if you are comfortable working around electricity.
- westendExplorerI would suggest you start with the shore power cord. Check with your meter if there is continuity between ground, neutral, or hot.
- rvingfunExplorerMy electric heating element on the hot water was fried (my fault since I forgot the bypass valve after winterizing) causing my house gfi to pop. That's how I knew it was element. As soon as I changed the element, problem solved.
- BeachumsExplorerKill everything at the converter, disconnect the batteries and isolate their leads if necessary. Plug it back in to your house. If it trips again, I would plug in the shore power cable without the TT plugged in to the other side...... that should give you a good idea where the problem is after you get through those steps.
One other thing, not to insult, but how well do you know that breaker circuit? Sometimes the garage circuit is tied to several outside receptacles as well as receptacles in one or more bathrooms. This is done to meet code for GFCI requirements and save money by putting the GFCI at the "top" of the circuit. The cheap skates that built my house did it that way.....it sucks - dodge_guyExplorer IIIs the GFI outlet bad? I`ve seen those go bad before. does the trailer work OK in a campground?
- DonkeyEarsExplorerMy batteries are at 2/3 full according to the meter. I'm using the same ext. cord and converter plug I've been using for 5 years with no issues. I use this at home to keep the batteries charged, but now it kicks the home breaker. Don't know, from what I'm reading here could be a number of things..
44,069 PostsLatest Activity: Jul 11, 2026
