Homeless_by_Cho
Oct 30, 2016Explorer
I don't believe that any of the Northern Lite campers are design to support a roll out tray nor is the compartment large enough to house a roller tray and the EU2000i. Like I said in an earlier reply there is only about one inch clearance on all four sides when the gen set is in the compartment. The bottom of the compartment has about a two inch inside radius on the two sides and the back and a one inch lip on the front edge. The roller tray would have to accommodate that somehow without interfering with the top opening.
The N-L has a well designed compartment for manually lifting the gen set in and out. How is the rear exhaust of the gen set going to be accommodated without extending its overall length? I believe that there are too many space and design issues to overcome. Good luck on finding a solution.
I did buy but never used a six foot plastic coated bicycle cable to go thru the handle of the gen set and around the camper tie down to lock it in place. Also, while I was in Fairbanks at a city campground, a man there was telling me that a pickup truck with two people in the back pulled up along side of him, got out their bolt cutter, cut his cable, and made off with his Honda while it was still running in less than five seconds.
LeRoy
LeRoy
44,056 PostsLatest Activity: Jan 22, 2026
