- TucsonJimExplorer IIAccording to the spec sheet for this unit, the output voltage is 120V, 1000 Watts Max. It does not list any tolerance for this voltage. So, if you're seeing 125 Volts, you are running about about 4% over the rated voltage which is probably okay.
- TucsonJimExplorer IISounds a bit high. Just to be sure, what are you measuring the voltage with?
- afraid_of_bearsExplorerThis would be when running just the converter to charge the batteries. Fridge is on propane.
- Dennis_SmithExplorerIs this pulling a load or just running?
44,056 PostsLatest Activity: Mar 02, 2026
