sky_free wrote:
bob213 wrote:
sky_free wrote:
msiminoff wrote:
Hi Tim,
I also have a Honda EU2000i and Polar Cub A/C...
I sugest that you try adding a Supco SPP6 hard start capacitor. The cost about $15 and installation is simple.
Cheers
-Mark
I actually used the SPP6E. One other thing to remember is that the newer A/C units use less electricity. When I was doing this mod I found that the Dometic 13.5's made in the last few years use a couple of amps less than the ones made 10+ years ago. Even so, the SPP6/E solution should help you. Here are some instructions I found Mod My RV SPP6
If you scroll down to about the 116th comment on this article you will find this....
1. Jim Berry (July 13th, 2011 at 7:22 am)
If you are adding a hardstart to your RV A/C unit, use the SPP6 (no E). The SPP6E is not designed for 120VAC applications, The “E” series is also an instant restart unit, this does not allow the generator sufficient time to rampup to full power. The SPP6 has the preferred PTC relay and allows a longer ramp up time. The SPP6 is rated for 120VAC usage.
Remember for every thousand feet above sea level you generator drops 3% of output. On hotter days the A/C drops in efficiency as well. Check with your A/C manufacturer on the correct generator size for your unit. As far as I know there is not a manufacturer that will reccomend a 2000 watt generator to run a 13,500 BTU A/C unit.
If you have any questions about the SPP6 or any other Supco part, please contact us at 1-800-333-9125 ext. 261 our Tech Support will be glad to assist you.
Thanks,
Jim Berry
Director Product Management
Sealed Unit Parts Co., Inc.
Sorry, I was wrong. I did indeed use the SPP6. I had to look back at my order history.
I did use the SPP6. But I also noticed that my A/C unit already had a start capacitor on it from the factory. I just added the SPP6 in addition. Do I need to remove the factory start capacitor?
