Ripit wrote:
S Davis wrote:
Does the voltage dip when you try and start the AC on the generator? I have seen units that had enough voltage drop that the control circuits would not work. If the secondary control voltage drops to much you can have issues like relays not pulling in.
Yes, when I tested the voltage the other day it dropped to 90 then 60 then 30 then 15. But usually it doesn't even try to start at all. That was the only one of two time it as even tried to start.
If the Honda is dropping the voltage all the way down without tripping its overload circuit that has to be your problem.
