Ripit wrote:
... Rvcomfort tech support and the guy said "that Honda 2000 won't run that A/C especially if it was hotter than 85 degrees. He gave me the max start up amps and voltage and told me to call Honda after I reminded him that all of YOU do just fine. He had no answer for that but he said to call Honda and ask them if it could handle the loads. Honda said probably not. ...
My primary confusion can from your being ask if the charger/inverter was off, and you said yes. Also you were ask to turn everything off except the A/C only, and your response was you did.
Well, the main thing is your A/C does work with your Polar Cub. It is sure disappointing to me that Rvcomfort tech support (polar Cub) and Honda said the Honda 2000 would not or probably would not run the {Polar Cub. Kinda looks like they both need to change Techs.
Wayne
