Me_Again's avatar
Me_Again
Explorer III
Oct 12, 2019
Honda eu2000i separate on/off switch
I had a eu1000i for many years and now a eu2000i for 2 years, the thing I did/do not like is one can not run the carb dry. So I added a separate run switch to the eu1000i and today to the eu2000i. The 2000 was much easier, as I was able to reach is and cut the two wires between the fuel/run switch and plug, and extend them to the new switch without taking the case apart. The switch I got at Ace Hardware is advertised at having an O-ring to keep moisture out.
BTW the switch closes to stop the generator, so I could not use the little on/off tab, as it was reversed for this application.
Chris
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
