Reddog1 wrote:
Ripit wrote:
Wayne, when I was ask to turn everything off I did that. I put the charger in the off position on the control panel and turned off all other appliances.
This is where I am a little stumped. The Handa should have ran the Polar Cub, with everything off (including the charger) except the A/C.
I do not turn my charger off to run my Polar Cub, but it probably is not doing much for charging at that point. I guess if the battery was down, my Honda may not run my Polar Cub.
Wayne
I'm not really sure exactly how to the drop out works. I'm assuming since it was set so high that the inverter was shutting off the power totally instead of inverting to help the AC start or not allowing to start. The Tech at Magnum was surprised that the AC was run through the inverter. He said usually they don't recommend the AC to run through there inverters. But he said if it worked it was ok. I was going to but never did run a wire directly from the AC to the genny to see if it would run that way. In any case I ran the system several times last night just to be sure everything worked and had no issues. Hopefully this will continue to work fine.
