hohenwald48
Aug 18, 2015Explorer
christopherglenn wrote:hohenwald48 wrote:wanderingbob wrote:
It should be easy if you can get to the back . Why would you want to take it out ? In the back just jump across the run connection , put it on a toggle .All the key is really for is to engage the starter and make the run connection . I have one mounted in my truck for seven years and have never taken the key out or turned it off . To shut mine off I shut off the fuel and walk away , it runs for a minute and then shuts down .
Because I want to leave the generator running when I'm not around and I don't want to give someone a way to shut it down. I hadn't thought about just turning off the fuel. I guess I'd have to address that too. I may need to think a little more. Maybe a locking door to cover the whole control panel.
Leave it running when you are not around and don't want to give anyone a way to shut it down? I hope you are not trying to make friends camping. They can always unplug it to get back at you, or pour water in the gas tank to shut it down.
Thanks for your helpful input.
